night_surfer
Sep 15, 2014Aspirant
amule installation and starting problem
Hi all, i've found a problem un my RN104: when i try to start amule (manually installed with the right arm package) the NAS system switch it off automatically after a few seconds and give me the fol...
night_surfer
Nov 17, 2014Aspirant
Hi Crazy72, first of all thanks for the help. I will try your solution when I will come back at home, actually i'm travelling for work.
When i will do it, i will give you the result!
Thanks very much!
Filippo
Thanks very much!
Filippo
