night_surfer
Sep 15, 2014Aspirant
amule installation and starting problem
Hi all, i've found a problem un my RN104: when i try to start amule (manually installed with the right arm package) the NAS system switch it off automatically after a few seconds and give me the fol...
Tay1
Dec 22, 2014Aspirant
Ok, just to let other people with the same problem know that I was able to get aMule up and running.
There are 2 commands you need to launch, as crazy72 reported:
amuleweb --amule-config-file=/data/amule/amule.conf &
/usr/bin/amuled -c /data/amule/ &
the program should be started with the "&" suffix, running in background
in my case "monit" program did not work, so I created an executable script and made it start at boot using rc.d
Enjoy aMule on ReadyNAS!
