jhagg
Feb 24, 2018Luminary
Any add-on available for Tautulli (PlexPy V2)
Hello, I am wondering if developer such as Myhnlo can provide an add-on for the new PlexPy V2 called Tautulli? This would be very helpful! http://tautulli.com/
- Mar 13, 2018
Hi guys!
Just to inform you that IF you had PlexPy by Myhnlo installed (pre 2.xx.x) it will AUTOUPDATE to Tautulli VERSION V2.0.22..
No need to get an updated appinstaller.
I had earlier PlexPy installed. Installed the TauTulli BETA 2.xx.xx and run both versions on different ports.
Just the other day, PlexPy became Tautulli and was autoupdated.
Then i just shutdown the BETA version and only runs the "old" newly updated version.
It is still visible as PlexPy in apps. And you can still use the On/Off switch as normal.
Small info.. Lots of text.. :-)
Regards
Hans
Marc_V
Feb 26, 2018NETGEAR Employee Retired
Hi jhagg
Checked https://github.com/tautulli/Tautulli-Wiki/wiki/Installation and indicates that you need to have Phyton 2.7 installed to support the app. You might want to check https://rnxtras.com for that. Then Tautulli will work on the Plexpy app developed by @Myhnlo.
Might as well send the developer a PM to confirm this.
hope this helps!
