jhagg
Feb 24, 2018Luminary
Any add-on available for Tautulli (PlexPy V2)
Hello, I am wondering if developer such as Myhnlo can provide an add-on for the new PlexPy V2 called Tautulli? This would be very helpful! http://tautulli.com/
- Mar 13, 2018
Hi guys!
Just to inform you that IF you had PlexPy by Myhnlo installed (pre 2.xx.x) it will AUTOUPDATE to Tautulli VERSION V2.0.22..
No need to get an updated appinstaller.
I had earlier PlexPy installed. Installed the TauTulli BETA 2.xx.xx and run both versions on different ports.
Just the other day, PlexPy became Tautulli and was autoupdated.
Then i just shutdown the BETA version and only runs the "old" newly updated version.
It is still visible as PlexPy in apps. And you can still use the On/Off switch as normal.
Small info.. Lots of text.. :-)
Regards
Hans
Marc_V
Mar 06, 2018NETGEAR Employee Retired
Hi jhagg
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- Dec 07, 2015Retired_Member
