jhagg
Feb 25, 2018Luminary
Any add-on available for Tautulli (PlexPy V2)
Hello, I am wondering if developer such as Myhnlo can provide an add-on for the new PlexPy V2 called Tautulli? This would be very helpful! http://tautulli.com/
- Mar 13, 2018
Hi guys!
Just to inform you that IF you had PlexPy by Myhnlo installed (pre 2.xx.x) it will AUTOUPDATE to Tautulli VERSION V2.0.22..
No need to get an updated appinstaller.
I had earlier PlexPy installed. Installed the TauTulli BETA 2.xx.xx and run both versions on different ports.
Just the other day, PlexPy became Tautulli and was autoupdated.
Then i just shutdown the BETA version and only runs the "old" newly updated version.
It is still visible as PlexPy in apps. And you can still use the On/Off switch as normal.
Small info.. Lots of text.. :-)
Regards
Hans
viperhansa
Mar 13, 2018Virtuoso
Hi guys!
Regards
Hans
- MhynloMar 22, 2018Luminary
I was keeping my eye on its release and held back till some the issues with the early betas and upgrading to Tautulli. I have split the apps into the newer app naming (Tautulli) and added a migration of the older PlexPy data to the Tautulli app.
https://github.com/Mhynlo/rn-plexpy/releases/latest
You can also update the PlexPy app, but I am going to be phasing the PlexPy version of the app out.
