jhagg's avatar
jhagg
Luminary
Feb 25, 2018
Any add-on available for Tautulli (PlexPy V2)
Hello,   I am wondering if developer such as Myhnlo can provide an add-on for the new PlexPy V2 called Tautulli?  This would be very helpful!   http://tautulli.com/
  • viperhansa's avatar
    Mar 13, 2018
    Hi guys!
    Just to inform you that IF you had PlexPy by Myhnlo installed (pre 2.xx.x) it will AUTOUPDATE to Tautulli VERSION V2.0.22..
    No need to get an updated appinstaller.
    I had earlier PlexPy installed. Installed the TauTulli BETA 2.xx.xx and run both versions on different ports.
    Just the other day, PlexPy became Tautulli and was autoupdated.
    Then i just shutdown the BETA version and only runs the "old" newly updated version.
    It is still visible as PlexPy in apps. And you can still use the On/Off switch as normal.
    Small info.. Lots of text.. :-)
    Regards
    Hans
ProSupport for Business
