sunsina
Aug 12, 2015Guide
Any plan for officially upgrading pydio and php?
I am wondering why the appications on the application market OS 6.3.5 are so outdated. As an example Pydio is very outdated (v5.2.3) and the latest version is 6.0.8 (which recommends php >5.6.x) Ne...
sunsina
Aug 15, 2015Guide
Hi,
This is the error that I get
# dpkg -i pydio_6.0.8_all.deb Selecting previously unselected package pydio. (Reading database ... 17310 files and directories currently installed.) Unpacking pydio (from pydio_6.0.8_all.deb) ... --2015-08-15 16:20:30-- http://www.dotdeb.org/dotdeb.gpg Resolving www.dotdeb.org (www.dotdeb.org)... 195.154.242.153 Connecting to www.dotdeb.org (www.dotdeb.org)|195.154.242.153|:80... connected. HTTP request sent, awaiting response... 200 OK Length: 5299 (5.2K) [application/octet-stream] Saving to: ‘dotdeb.gpg’ dotdeb.gpg 100%[==================================================================>] 5.17K --.-KB/s in 0s 2015-08-15 16:20:30 (118 MB/s) - ‘dotdeb.gpg’ saved [5299/5299] OK dpkg: dependency problems prevent configuration of pydio: pydio depends on php5-gd (>= 5.6.4~); however: Version of php5-gd on system is 5.4.41-0+deb7u1. pydio depends on php5-pthreads; however: Package php5-pthreads is not installed. dpkg: error processing pydio (--install): dependency problems - leaving unconfigured Errors were encountered while processing: pydio
Would you mind kindly tell me step by step how can I fix the dependencies errors?
I suppose that the PHP5.6 is included in this .deb package
Thanks
mdgm-ntgr
Aug 16, 2015NETGEAR Employee Retired
No. You need to install the PHP5.6 package first.
- sunsinaAug 19, 2015Guide
Where and how?
Is it avaliable on ReadyNAS repository or shall I download it as a debian package that is avaliable on the community dropbox which is 12KB!?
I tried the 12KB .deb package on the community dropbox and I still get following problem.dpkg: dependency problems prevent configuration of pydio:
Package php5-pthreads is not installed.dpkg: error processing pydio (--install):
Errors were encountered while processing:- super_poussinAug 19, 2015Virtuoso
Take a look here : https://www.dropbox.com/sh/ckfbxakh54ujujy/AADSzLvxBhz9Cp1hXMEYuBUCa?dl=0
Read the text file and pleas einstall it from gui :)
- sunsinaAug 23, 2015Guide
Hi,
I already read the readme_1st.txt file I tried a couple of times-more than 3 times! gui installation and I always get System: Failed to install application 'pydio_6.0.8_all.deb'.I also tried apt-get update , and dpkg -i pydio_6.0.8_all.deb
I GET SAME ERRORS
In addition I have no owncloud on my NAS,dotdeb.gpg 100%[=======================================================================================================================================>] 5.17K --.-KB/s in 0s 2015-08-23 14:06:30 (108 MB/s) - ‘dotdeb.gpg’ saved [5299/5299] OK dpkg: dependency problems prevent configuration of pydio: pydio depends on php5-gd (>= 5.6.4~); however: Version of php5-gd on system is 5.4.41-0+deb7u1. pydio depends on php5-pthreads; however: Package php5-pthreads is not installed. dpkg: error processing pydio (--install): dependency problems - leaving unconfigured Errors were encountered while processing: pydio
I have following apps installed on my system (I have no clue if something is missed or not!!!!)
My RDNAS-OS version is 6.3.5
Symform 4.24.0
MySql Server 1.0.1SMB Plus 1.0.3
Transmission for ReadyNAS 3.00.8
htop 1.0.0
Pydio package 6.0.8-14MB provided on your dropbox is not at all installing (Even several time trying via GUI,TERMINAL).
I think you have updated/installed php on your device in different way.
- Sep 04, 2015Retired_Member
