cosmos1
Oct 25, 2012Aspirant
Anyone interested in compiling rtorrent for Duo V2?
Hello all, I've been using rtorrent with specific setting on my previous NAS box, a meagre Maxtor Shared Storage II with great results. After obtaining my Readynas duo v2 box and being informed tha...
cosmos1
Nov 10, 2012Aspirant
Ok some initial testing. Download goes fine so far, however preallocation seems to not be working. Specifically, downloading a 700Mb file via enhanced-ctorrent (package "ctorrrent") and enabling preallocate for it (via a "-a" command line option) immediately creates a single 700Mb file, for which the following data are shown:
ctorrent immediately allocates the entire file, before starting to download. On my old Maxtor Shared Storage II, that's how rtorrent also worked. I understood it worked that way because filefrag showed the exact same data, regardless if I run ctorrent with the preallocate option or rtorrent with the preallocate option.
Additionally, on my old platform, the files were not created with preallocation until the very first write access attempt. At that point, my rtorrent would pause for a while (probably because the preallocation routine was a blocker) and only after the file was completely created/allocated only then it would unfreeze and downloading would actually take place...
For some reason, this does not seem to be the case here, perhaps I'm missing out something. In the test file above, as time passes so does the output of filefrag changes. The extents used remain 2, but it seems that the file is heavily fragmented:
I do know that my MSS used ext3, whereas this duo is using ext4 (not using Xraid here, just Flex-raid with JBOD). Could the preallocate function be that different in ext4?
# filefrag -v file.mp4
File size of file.mp4 is 892549374 (217908 blocks, blocksize 4096)
ext logical physical expected length flags
0 0 369389568 32768
1 32768 369422336 32768
2 65536 369455104 32768
3 98304 369487872 32768
4 131072 369520640 2048
5 133120 369524736 369522687 32768
6 165888 369557504 32768
7 198656 369590272 19252 eof
file.mp4: 2 extents found
0 0 369158144 30720 unwritten
1 30720 369188864 30720 unwritten
2 61440 369219584 30720 unwritten
3 92160 369250304 30720 unwritten
4 122880 369281024 2048 unwritten
5 124928 369285120 369283071 9728 unwritten
6 134656 369294848 101
7 134757 369294949 27803 unwritten
8 162560 369322752 16
9 162576 369322768 12
10 162588 369322780 164
11 162752 369322944 4
12 162756 369322948 60
13 162816 369323008 256 unwritten
14 163072 369323264 112
15 163184 369323376 144 unwritten
16 163328 369323520 198
17 163526 369323718 10
18 163536 369323728 5
19 163541 369323733 3 unwritten
20 163544 369323736 144
21 163688 369323880 4 unwritten
22 163692 369323884 36
23 163728 369323920 4 unwritten
24 163732 369323924 44
25 163776 369323968 4
26 163780 369323972 32
27 163812 369324004 8 unwritten
28 163820 369324012 5
29 163825 369324017 15 unwritten
30 163840 369324032 14
31 163854 369324046 1266 unwritten
32 165120 369325312 51
33 165171 369325363 21 unwritten
34 165192 369325384 6
35 165198 369325390 13746 unwritten
36 178944 369339136 256
37 179200 369339392 6144 unwritten
38 185344 369345536 349
39 185693 369345885 27555 unwritten
40 213248 369373440 256
41 213504 369373696 4404 unwritten,eof
