cosmos1
Oct 25, 2012Aspirant
Anyone interested in compiling rtorrent for Duo V2?
Hello all, I've been using rtorrent with specific setting on my previous NAS box, a meagre Maxtor Shared Storage II with great results. After obtaining my Readynas duo v2 box and being informed tha...
cosmos1
Nov 12, 2012Aspirant
Arghhhh, just lost firefox and the entire response I was writing!!!!
Anyways, thanks again for your awesome help mate, much appreciated. Okay, download and install both rtorrent as well as "enhanced-ctorrent" (if not available, install "ctorrent", they should be the same).
Do a port forward for ports 30000-30005 on your router, both TCP and UDP, to the IP of your test NAS. Create a ~/session and a ~/work directory. Create a ~/.rtorrent.rc file:
Download a torrent file that has a single large (ie ~700Mbyte) file in it. Then use rtorrent to download it. You'll end up with a large file. Do a "filefrag -v <file>" on the resulting large file and post/check the result. If filefrag does not exist, then install package e2fsprogs.
Now do the same download, with the following command, on another directory:
You'll end up with the same large file, albeit download from ctorrent. Do a "filefrag -v <file>" on the resulting file as well. Compare results.
min_peers = 20
max_peers = 100
upload_rate = 60
directory = ~/
session = ~/session
ratio.enable= ; Enables rtorrent to use ratio's.
ratio.min.set=110 ; Set min ratio to 1.0 / 1.0 upload / download.
port_range = 30001-30005
port_random = yes
use_udp_trackers = yes
encryption = allow_incoming,enable_retry,prefer_plaintext
dht = auto
dht_port = 30000
peer_exchange = yes
system.file_allocate.set = yes
mkdir ~/test
cd ~/test
ctorrent -a -E 1.1 -U 60 -p 30005 <sametorrentfile.torrent>
