cosmos1
Oct 25, 2012Aspirant
Anyone interested in compiling rtorrent for Duo V2?
Hello all, I've been using rtorrent with specific setting on my previous NAS box, a meagre Maxtor Shared Storage II with great results. After obtaining my Readynas duo v2 box and being informed tha...
cosmos1
Feb 18, 2013Aspirant
Been some time since our last chat. I don't know if you are still interested (I am for certain) to throw a couple of tests. I am especially interested on whether certain symbols get defined or not. You see, the login for preallocation is in libtorrent in file src/data/socket_file.cc. Can you tell which of the following symbols get defined after running configure?
* HAVE_FALLOCATE
* USE_POSIX_FALLOCATE
I am interested in those two, because they define which method is used when the user selects preallocation. In that scenario, creation of a file happens through Socketfile::set_size (if I understand correctly). In the following, I've pasted this function, removing the SYS_DARWIN check:
I am asking which of HAVE_FALLOCATE and USE_POSIX_FALLOCATE get used here, because I'd like to short circuit perhaps one or the other or both, in order for the preallocation to work properly... If HAVE_FALLOCATE is defined, then according to the piece of code above, preallocation always happens through a call to fallocate. Otherwise, if HAVE_FALLOCATE is not defined but USE_POSIX_FALLOCATE is, then preallocation happens through posix_fallocate... If neither exists, then allocation happens through the following catchall piece of code:
* HAVE_FALLOCATE
bool
SocketFile::set_size(uint64_t size, int flags) const {
if (!is_open())
throw internal_error("SocketFile::set_size() called on a closed file");
#ifdef HAVE_FALLOCATE
if (flags & flag_fallocate && fallocate(m_fd, 0, 0, size) == 0)
return true;
#endif
#ifdef USE_POSIX_FALLOCATE
flags & flag_fallocate_blocking &&
posix_fallocate(m_fd, 0, size) == 0)
return true;
#endif
#ifdef SYS_DARWIN
[...] We are not interested here, does not get executed
#endif
if (ftruncate(m_fd, size) == 0)
return true;
// Use workaround to resize files on vfat. It causes the whole
// client to block while it is resizing the files, this really
// should be in a seperate thread.
if (size != 0 &&
lseek(m_fd, size - 1, SEEK_SET) == (off_t)(size - 1) &&
write(m_fd, &size, 1) == 1)
return true;
return false;
return true;
if (size != 0 &&
return true;
return false;
