Retired_Member
Oct 12, 2017Application dissapeared from ReadyNAS "Installed Apps" after 6.8 or 6.8.1
Hi, i have teamspeak server at my ReadyNAS running. Since version 6.8 upgrade or 6.8.1 upgrade, teamspeak icon dissapeared from frontend of "Installed apps". Could you help? I have checked: - te...
Marty_M
Oct 18, 2017NETGEAR Employee Retired
Hello soundguy1,
There was an issue raise that after upgrading the firmware to 6.8.0 where apps installed where no longer on the list of installed apps but the issue was address on firmware version 6.8.1. If your NAS is already running on the latest firmware please try to reboot it and try accessing the admin page using different browser and computer for isolation. If the problem persist there is a possibility that the app is not yet compatible with the latest firmware, you may want to check with the developer of the app.
Marty_M
NETGEAR Community Team
- Marty_MOct 22, 2017NETGEAR Employee Retired
Hello soundguy1,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance. If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Marty_M
NETGEAR Community Team - Retired_MemberOct 25, 2017
Hi Marty_M,
The current state is, that I have 2 custom apps compatible with ReadyNAS 6.8.1 (that i have installed). Apps were installed using SSH and unpacking files into appropriate folders. Both apps are running ok and working ok including their services. Apps setup is normally accessible via web browser.
The problem is, that i do not see the second app in "Installed Apps". So i cannot restart or turn off and on again application's service.
I see only 1 of 2 custom applications there. As it is shown in the image attached to a first post for this topic.
I am no developer, so i have copied config.xml using some guides from these forums (one for each app).
Maybe.. problem could be.. that both files have no <AppID> tag inside, only <CategoryName>. Is it mandatory tag?
Config.xml for teamspeak (the missing application in installed apps) is included into a first post. Pls look.
- Marty_MOct 26, 2017NETGEAR Employee Retired
Hello soundguy1,
It is possible that the version of the app is not yet compatible with the ReadyNAS OS6 firmware version. In any case that the app is not yet compatible with the new firmware, it is the developer that should update their app and submit it to Netgear.
Marty_M
NETGEAR Community Team- Marty_MOct 29, 2017NETGEAR Employee Retired
Hello soundguy1,
Marty_M
