Mfrick's avatar
Mfrick
Tutor
Dec 26, 2022
Install error reset "1"
I have an N300 wifi extender. It's was working but recently I couldn't connect to it. I tried the install assistant and got 'reset' ("1"). Did a factory reset. Tried again to connect thru the browser same error. Tried WPS install, same problem. Don't know what else to try.
  • I will accept but still baffled why it doesn't work using my phone. Thanks.
  • plemans's avatar
    1. what N300 device do you have? n300 is a speed, not a model
    2. what firmware is on it?
    3. what is giving you that error? Do you have a screen snip of it?
    4. what router are you connecting it to?
    • Mfrick's avatar
      Mfrick
      Tutor
      Router: VIASTAT ADP-90AR<br>Extender: WN3000RPv3<br>Plugged in extender. Green light on.<br><br>I launched my web browser<br>MYWIFIEXT<br>Login page flashes, replaced with a page that only says Reset: ("1") at he top rest of page is blank. <br>
      • plemans's avatar
        Take a screensnip of it.
        Is the extender disconnected from everything?
        Did you hit the wps button at any point? (if so factory reset it)
