Retired_Member
Oct 12, 2017Application dissapeared from ReadyNAS "Installed Apps" after 6.8 or 6.8.1
Hi, i have teamspeak server at my ReadyNAS running. Since version 6.8 upgrade or 6.8.1 upgrade, teamspeak icon dissapeared from frontend of "Installed apps". Could you help? I have checked: - te...
Marty_M
Oct 26, 2017NETGEAR Employee Retired
Hello soundguy1,
It is possible that the version of the app is not yet compatible with the ReadyNAS OS6 firmware version. In any case that the app is not yet compatible with the new firmware, it is the developer that should update their app and submit it to Netgear.
Marty_M
NETGEAR Community Team
Marty_M
Oct 29, 2017NETGEAR Employee Retired
Hello soundguy1,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance. If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Marty_M
