thunoldolsen
Aug 08, 2016Aspirant
Backup-tab of Photos 2 not showing in advanced settings
Hi, I have a Readynas 312 with latest firmware and Photos 2 v 2.0.5 I have read in the documentation that it is possible to activate a scheduled backup of Photos 2 images to a folder on the R...
- Aug 16, 2016
I was not satified with the answer so I did the following:
1. I stopped using Photos 2. I tried Piwigo and it was much better.
2. I created a share and synced it with Amazon Drive. Every time a file is added to the share it syncs with amazon drive.
3. I created a cron job that uses rsync to sync the piwigo-imagefolder with the (image)share i just created. I have set the cronjob to rsync the folders every six ours. If Photos 2 users want to do the same they just rsync the photos folder instead.
Mikal
JohnRo
Aug 15, 2016NETGEAR Employee Retired
Hi thunoldsen,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
thunoldolsen
Aug 16, 2016Aspirant
Mikal
- BrianL2Aug 16, 2016NETGEAR Employee Retired
Hi thunoldolsen,
I apologize again but this backup feature of the ReadyNAS Surveillance is unavailable on the newer ReadyNAS models. I'm glad that you're able to make your own workaround to backup your (Piwigo) photos using RSYNC. Thank you for also sharing this in the community.
Kind regards,
BrianL
NETGEAR Community Team
