Blueray3
Jul 01, 2017Guide
Backup to DropBox
Can someone interpret the info bubble on the Dropbox cloud feature in the Cloud section of OS 6? "Selecting root folder will sync entire public cloud, preventing you from adding new sessions" ...
- Jul 10, 2017
Hi Blueray3,
Since the root folder is being sync, the message is just letting us know that there is no need to create other sessions for that root folder.
Marty_M
NETGEAR Community Team
Marty_M
Jul 02, 2017NETGEAR Employee Retired
Hello Blueray3,
Under the firmware version 6.7.5 after enabling ReadyDrop the you will be ask to set for "Local path" (NAS) and "Cloud path" (Dropbox) and set what type of sync direction will be followed.
As for the "Adding new sessions" it means that you can create a new session with same local path share/folder different cloud path folder or vice versa.
It is much easier setting up the ReadyDrop on the latest firmware version. I would recommend to setup ReadyDrop on your NAS running on the latest firmware version.
What firmware version is running on your readynas device?
Welcome to the community!
Marty_M
Marty_M
Jul 04, 2017NETGEAR Employee Retired
I think the public path you are referring is the same as cloud path. The dropbox setup is basically selecting a specific folder from your dropbox to sync with a specific share/folder on the NAS. The feature cannot sync the root of the dropbox to a share on the NAS.
Marty_M
