WSJ's avatar
WSJ
Tutor
Jan 01, 2016
Baikal for ReadyNAS Duo (v1, Sparc)
I'm wondering whether anyone has managed / attempted to run Baikal on ReadyNAS Duo (Sparc).
It's much lighter than OwnCloud and for me it would serve the main tasks: CalDAV and CardDAV.
Currently I'm using OwnCloud but that's pretty heavy for the little Duo.
Am I alone with that idea? Hopefully not...
Looking for comments...
  • WSJ's avatar
    WSJ
    Jul 28, 2017
    Finally I've got a ReadyNAS Pro 6 with OS 6.7.5 - and thus I'm able to use Baikal (aka "Contacts and Calendars Server" app).
  • BrianL2's avatar
    BrianL2
    NETGEAR Employee Retired
    Hi WSJ,
    Welcome to the community!
    ReadyNAS Duo (4.1.x) is already EOL. Having Baikal as an additional add-on is unlikely. If you want to check the add-ons related to SQL, calendar and etc. all of them are available here.
    Let me know if you have other questions.
    Kind regards,
    BrianL
    NETGEAR Community Team
    • WSJ's avatar
      WSJ
      Tutor
      I'm not expecting Netgear to provide such an Add-On.
      But I was asking the community whether anyone has such plans in mind - or can judge the feasibility.
      Since there's even an Owncloud Add-On, it should be technically feasible to support Baikal.
      • StephenB's avatar
        WSJ wrote:
        ... or can judge the feasibility.
        Perhaps reach out directly to WhoCares_ either via PM or at rnxtras.com.  He can likely give you an accurate assessment very quickly.
ProSupport for Business
