xushi
Dec 01, 2015Aspirant
bash upgrade
Hi all, I have 2 x ReadyNAS NV+ v1 on 4.1.14 that are of course past their shelf life in terms of development and support.. I enabled SSH access to them as I no longer have a jump box with t...
mdgm-ntgr
Dec 01, 2015NETGEAR Employee Retired
If you want to do some experimenting you could power down, remove your disks (label order), put a scratch disk in and have a go with that.
xushi
Nice idea!
I presume I can settle with putting just 1 spare disk in there right? There's no need to fill up all 4 slots.
And after fiddling around, I can just put back the original 4, boot up and it's as if nothing happened ?
I was hoping someone else would have had some experience with updating bash, before I go into testing myself, but if not, I'll proceed and update the thread with my results later on.
- mdgm-ntgrDec 01, 2015NETGEAR Employee Retired
Yes.
Well I think there's a strong possibility you may/will run into problems doing such an update. Personally at this point I think you'd be better off getting an OS6 NAS than trying to update things like bash on a Sparc unit.
- xushiDec 01, 2015Aspirant
True,
But they still work fine (and were pricy!), can handle 4 x 2TB disks each in XRaid, and don't feel outdated or useless yet.. It would be a shame to retire them.
It also leaves me with the concern that the OS6 NAS will end up in a similar fate soon enough, leaving me stuck.
