curry100
May 12, 2012Follower
Bluetooth Advice - sma-bluetooth
Hello, 1st time poster here. I'm in the process of migrating squeezebox server, bundle of my perl scripts etc. from a CentOS server which died over to a smaller power ReadyNAS Dou(v1) and that's g...
optimus1
Aug 02, 2012Aspirant
A follow up.
I've downloaded the GPL sources, extracted the kernel files and run a `make menuconfig`. I enabled the only bluetooth item I could see (under 'USB Devices -> bluetooth (experimental)'). However when I then run a `make dep` or `make` I get the following error message:
Does this mean there's a problem with the src files in the GPL download? Or maybe make menuconfig isn't setting something correctly?
sparc-linux-gcc -D__KERNEL__ -I/opt/linux-infrant-2.4.20/include -g -Wall -Wstrict-prototypes -Wno-trigraphs -O2 -fno-strict-aliasing -fno-common -fomit-frame-pointer -m32 -pipe -mno-fpu -fcall-used-g5 -fcall-used-g7 -S -o check_asm_data.s check_asm_data.c
check_asm_data.c:19: error: syntax error before numeric constant
check_asm_data.c:159: error: syntax error before '}' token
check_asm_data.c:5: warning: array `check_asm_data' assumed to have one element
make[1]: *** [check_asm] Error 1
make[1]: Leaving directory `/opt/linux-infrant-2.4.20/arch/sparc/kernel'
make: *** [check_asm] Error 2
soundwave:/opt/linux-infrant-2.4.20#
