dacarson
Jan 27, 2019Aspirant
Building Nodejs on ReadyNas
After many attempts, I was finally able to build Node on my ReadyNas.
For those who are trying to do this, I basically followed instructions here:
http://elsmorian.com/post/23474168753/nodej...
dacarson
Mar 18, 2019Aspirant
I can help you out with getting it to compile. Can you tell me which part of the instructions I point to are not working?
DMod
Mar 23, 2019Tutor
Are you compiling it on the NAS or on your computer then transfering it over to install?
I was having trouble typing out
$ git checkout v10.15.0
so I just downloaded the files onto my computer. I entered
$ export CCFLAGS='-march=armv7-a' $ export CXXFLAGS='-march=armv7-a'
like you said and commented out the line in the code. When trying to run make I'm getting this error but I'm running make on my computer.
node/node-master/out/Release/obj.target/icuucx/deps/icu-small/source/common/uniset_props.o.d.raw -march=armv7-a -c ../deps/icu-small/source/common/uniset_props.cpp:1:0: error: bad value (armv7-a) for -march= switch // © 2016 and later: Unicode, Inc. and others. ^ tools/icu/icuucx.target.mk:290: recipe for target '/home/m/node/node-master/out/Release/obj.target/icuucx/deps/icu-small/source/common/uniset_props.o' failed make[1]: *** [/home/m/node/node-master/out/Release/obj.target/icuucx/deps/icu-small/source/common/uniset_props.o] Error 1 Makefile:99: recipe for target 'node' failed make: *** [node] Error 2
I'm logged in as root through ssh. What steps do I now take? Is there a reason why not installing it through apt instead?
- dacarsonMar 23, 2019Aspirant
I am compiling it on the NAS. It isn't fast, but that seemed better for me as I didn't want to mess with cross-compiling on another computer.
I checked out the code directly onto the ReadyNAS. To do this I installed the git tools as well as other libraries needed for building node:
apt-get install git-core build-essential libssl-dev
then cloned the repo:
git clone https://github.com/nodejs/node
then updated to the particular version:
cd node git checkout v10.15.0
Then started the build:
./configure make
You'll get this error:
g++ -o /root/node/out/Release/obj.host/v8_libbase/deps/v8/src/base/platform/platform-posix.o ../deps/v8/src/base/platform/platform-posix.cc '-DV8_GYP_BUILD' '-DV8_TYPED_ARRAY_MAX_SIZE_IN_HEAP=0' '-DV8_TARGET_ARCH_ARM' '-DCAN_USE_ARMV7_INSTRUCTIONS' '-DV8_EMBEDDER_STRING="-node.45"' '-DENABLE_DISASSEMBLER' '-DV8_PROMISE_INTERNAL_FIELD_COUNT=1' '-DV8_INTL_SUPPORT' '-DV8_CONCURRENT_MARKING' '-DDISABLE_UNTRUSTED_CODE_MITIGATIONS' -I../deps/v8 -pthread -Wall -Wextra -Wno-unused-parameter -fno-strict-aliasing -mfpu=vfp -marm -fdata-sections -ffunction-sections -O3 -O3 -fno-omit-frame-pointer -fno-rtti -fno-exceptions -std=gnu++1y -MMD -MF /root/node/out/Release/.deps//root/node/out/Release/obj.host/v8_libbase/deps/v8/src/base/platform/platform-posix.o.d.raw -c /tmp/cc5aW9sQ.s: Assembler messages: /tmp/cc5aW9sQ.s:994: Error: selected processor does not support ARM mode `bkpt 0' deps/v8/gypfiles/v8_libbase.host.mk:129: recipe for target '/root/node/out/Release/obj.host/v8_libbase/deps/v8/src/base/platform/platform-posix.o' failed make[1]: *** [/root/node/out/Release/obj.host/v8_libbase/deps/v8/src/base/platform/platform-posix.o] Error 1 Makefile:99: recipe for target 'node' failed make: *** [node] Error 2
so I commented out the line that had 'bkpt 0'
and then kick off make again and wait... it takes a long time
re: Is there a reason why not installing it through apt instead?
I would install it via apt but AFAIK it is not available for ReadyNAS
- DModMar 24, 2019TutorI was having problems with the system not realizing that it was installed but I was able to install npm and node.js with apt.
Thank you for taking the time to write out the way you installed it, I think I'm going to remove it and go the way you said instead.- givememynamebakJun 26, 2019Luminary
Don't you just have to add its location in your PATH?
