x219c
Jan 26, 2017Luminary
Built in Antivirus 6.6.1
Hello, I can't for the life of me find where to configure this new antivirus... Any suggestions? I searched "antivirus" here and sorted by date, but I can't believe nobody's been asking about thi...
x219c
So, there's no way to configure the way the antivirus behaves? Are there any plans to provide this functionality?
It wasn't much before, but at least it was something... I had no idea this was going away from reading the release notes. I may not have been so hasty to update had I known.
- mitchathameJan 27, 2017Guide
I am also having issues with the new antivirus app due to not being able to modify its behavior. When are we going to get some control back of this app? These virus threats have only just appeared on files that havent changed. also.
"Antivirus scanner found a threat (Heuristics.Broken.Executable) in the file /tmp/clamav-df9690a621089e71500d4b517f04a5f7.tmp/content.019 (deleted). Please delete the infected file soon if automatic delete setting is not enabled." where is the /tmp refered to here and if its deleted how do i delete it?
- aalexandrebetaJan 27, 2017Master
Can people from Netgear explain me a dummy how it is working?
Delete options, its behaviour when the unit restart and does it restart the check from the begining?
A bit lost in space I am too!!
