x219c
Jan 26, 2017Luminary
Built in Antivirus 6.6.1
Hello, I can't for the life of me find where to configure this new antivirus... Any suggestions? I searched "antivirus" here and sorted by date, but I can't believe nobody's been asking about thi...
mdgm-ntgr
Jan 26, 2017NETGEAR Employee Retired
You can enable/disable the service under System > Settings > Services. The AV Plus app is incompatible with 6.6.1 and if you had that installed it would have automatically been uninstalled.
pstanley54
Jan 28, 2017Initiate
Antivirus scanner found a threat (Unix.Trojan.Mirai-5607459-1) in the file /bin/busybox. Please delete the infected file soon if automatic delete setting is not enabled.
I don't have access to /bin and the Antivirus App does not have any management capabilities other than Start and Stop. Am I safe? Diid the file get cleaned up and where did such a file come from? I didn't put it there.
- bedlam1Jan 28, 2017Prodigy
The AV app is totally borked, massive "fail" by Netgear I am afraid, turn it off
- aalexandrebetaJan 29, 2017Master
I agree with you!
