AGSowjet
May 08, 2017Apprentice
Can not activate Virus Scanner - ReadyNAS OS 6.6.1 problem with Firefox
Hi there, I just stumbled upon a minor bug, probably in the UI: when using Firefox (latest Version 53.0), I could not activate the Virus Scanner. Yes I did mark the Enable real-time antivirus sca...
JennC
May 08, 2017NETGEAR Employee Retired
Hello AGSowjet,
Are you referring to the AntiVirus? Please note that there has been an update on AntiVirus. The AntiVirus Plus app will no longer work.
Please see this post: ReadyNAS OS 6: Antivirus Update . Options
AGSowjet
May 10, 2017Apprentice
I am referring to the Virus Scanner which you can activate either from the main screen, the link next to the red/green antivirus status indicator, or by clicking the virus protection button on the System / Configuration page.
- StephenBMay 10, 2017Guru - Experienced User
This works correctly (with FireFox) on my RN526 - running OS 6.7.1.
So you might want to try upgrading your firmware and checking it again.
- AGSowjetMay 10, 2017Apprentice
I am always using the latest firmware. 6.6.1 is the latest version available to my model (RN104) right now, I just checked manually.
Netgear always does release for manual upgrades first, and then puts them on the "check for update" servers after a delay.
6.7.1 production is available for your RN104, and you can get it here: https://kb.netgear.com/000038557/ReadyNAS-OS-6-Software-Version-6-7-1
Though since this isn't particularly urgent, you could just wait a bit longer and use "check for update".
