AGSowjet
May 08, 2017Apprentice
Can not activate Virus Scanner - ReadyNAS OS 6.6.1 problem with Firefox
Hi there, I just stumbled upon a minor bug, probably in the UI: when using Firefox (latest Version 53.0), I could not activate the Virus Scanner. Yes I did mark the Enable real-time antivirus sca...
AGSowjet
May 10, 2017Apprentice
I am referring to the Virus Scanner which you can activate either from the main screen, the link next to the red/green antivirus status indicator, or by clicking the virus protection button on the System / Configuration page.
May 10, 2017Guru - Experienced User
This works correctly (with FireFox) on my RN526 - running OS 6.7.1.
So you might want to try upgrading your firmware and checking it again.
- AGSowjetMay 10, 2017Apprentice
I am always using the latest firmware. 6.6.1 is the latest version available to my model (RN104) right now, I just checked manually.
- StephenBMay 10, 2017Guru - Experienced User
Netgear always does release for manual upgrades first, and then puts them on the "check for update" servers after a delay.
6.7.1 production is available for your RN104, and you can get it here: https://kb.netgear.com/000038557/ReadyNAS-OS-6-Software-Version-6-7-1
Though since this isn't particularly urgent, you could just wait a bit longer and use "check for update".
- JennCMay 15, 2017NETGEAR Employee Retired
Hello AGSowjet,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- JennCMay 10, 2017NETGEAR Employee Retired
Hello AGSowjet,
Yes, we are referring to the same virus scanner, that is the built-in AntiVirus of ReadyNAS. There is also an app called AntiVirus Plus which works no longer works on firmware version 6.6.1 and later. If you would click the hyperlink I sent on my previous message, you would know.
Like StephenB mentioned, 6.7.1 is now available. It is available for manual update.
To manually/locally update the firmware, here are the steps:
- Log in to the ReadyNAS. On the local admin page, select System > Settings > Update.
- Click the Install Firmware button.
- Click the Browse button. In the pop-up file browser that displays, navigate to the file containing the updated firmware and select it. The Update Firmware pop-up screen displays the name of the selected file in the File Name field. Click the Upload button. The firmware file uploads to your ReadyNAS system. After a few moments, the Update Firmware pop-up screen displays details about the new firmware.
- Click the Install button. You are prompted to reboot your ReadyNAS system to complete the firmware installation.
- Reboot your ReadyNAS system. If you enabled email alerts, your ReadyNAS system sends a message when the firmware update finishes.
