AGSowjet
May 08, 2017Apprentice
Can not activate Virus Scanner - ReadyNAS OS 6.6.1 problem with Firefox
Hi there, I just stumbled upon a minor bug, probably in the UI: when using Firefox (latest Version 53.0), I could not activate the Virus Scanner. Yes I did mark the Enable real-time antivirus sca...
AGSowjet
May 10, 2017Apprentice
I am always using the latest firmware. 6.6.1 is the latest version available to my model (RN104) right now, I just checked manually.
May 10, 2017Guru - Experienced User
Netgear always does release for manual upgrades first, and then puts them on the "check for update" servers after a delay.
6.7.1 production is available for your RN104, and you can get it here: https://kb.netgear.com/000038557/ReadyNAS-OS-6-Software-Version-6-7-1
Though since this isn't particularly urgent, you could just wait a bit longer and use "check for update".
- JennCMay 15, 2017NETGEAR Employee Retired
Hello AGSowjet,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
