ReadyJustin
Dec 02, 2015Guide
Cannot copy files to Transmission "Downloads" directory
I'm running the Transmission 3.0.0.8 with ReadyNAS OS 6.4.1. When I try to copy files to the Downloads directory I get a permission denied error. Is this "by design" or is something wrong here? 'ls' ...
- Dec 07, 2015
(For anyone finding this later), since you cannot add files to the default Transmission and Incomplete folders:
1. Create a new folder in the Transmission network share named "Seed" and copy your file(s) there.
2. Get the .torrent file for the torrent (right click the entry in your Transmission list and "Save Torrent File As" if in another Transmission instance).
3. Open the torrent file in Transmission via the web interface or Transmission Remote GUI.
4. Specify your path for Destination folder, like /data/Transmission/Seed
5. Click ok, and Transmission will verify the data.
6. After data verification is complete, do "Force start" on the torrent.
ReadyJustin
Dec 02, 2015Guide
Yes to both. I also removed Transmission, removed the share, then reinstalled the app.
ReadyJustin
Dec 02, 2015Guide
As a test, I installed SickBeard. I'm able to copy files to the root of the sickbeard share, but not the Blackhole directory. The permissions show the same for both, just like for Transmission. In both cases I can copy to the root of the share but no directories as you said.
Is there any method to get the data to be seen by Transmission?
