ReadyJustin
Dec 02, 2015Guide
Cannot copy files to Transmission "Downloads" directory
I'm running the Transmission 3.0.0.8 with ReadyNAS OS 6.4.1. When I try to copy files to the Downloads directory I get a permission denied error. Is this "by design" or is something wrong here? 'ls' ...
- Dec 07, 2015
(For anyone finding this later), since you cannot add files to the default Transmission and Incomplete folders:
1. Create a new folder in the Transmission network share named "Seed" and copy your file(s) there.
2. Get the .torrent file for the torrent (right click the entry in your Transmission list and "Save Torrent File As" if in another Transmission instance).
3. Open the torrent file in Transmission via the web interface or Transmission Remote GUI.
4. Specify your path for Destination folder, like /data/Transmission/Seed
5. Click ok, and Transmission will verify the data.
6. After data verification is complete, do "Force start" on the torrent.
ReadyJustin
Dec 07, 2015Guide
Just 1 more note, which will come in handy for a bulk migration: you can multi-select torrent entries in Transmission for saving .torrent files as well as when doing the "open" action from the remote interface. Hope it helps someone out!
BrianL2
Dec 07, 2015NETGEAR Employee Retired
Hi ReadyJustin,
Great! Thanks for the additional info. I hope you will continue to share and post ideas in the community.
Kind regards,
BrianL
NETGEAR Community Team
