mfe_
Mar 04, 2012Tutor
cannt compile curlftpfs-0.9.2
Hello,
[Edit] Binaries of curlftps and installation instruction [/Edit]
curlftpfs seems to be very interesting because you will be able to mount ftp locations. http://curlftpfs.sourceforge.net/ for more informations.
I installed all dependencies like glib.
Its located in
I also set the variables of GLIB_CFLAGS and GLIB_LIBS with export variable=path
When compiling it with ./configure --build='sparc-linux' it breaks here:
I used the newest glib-2.30.2 version. What can i try else?
greetings
Its located in
ls /usr/local/lib/libglib-2.0.
libglib-2.0.la libglib-2.0.so libglib-2.0.so.0 libglib-2.0.so.0.3000.2
echo $GLIB_CFLAGS
/usr/local/lib/
echo $GLIB_LIBS
/usr/local/lib/
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by g++... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC
checking if g++ PIC flag -fPIC works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
appending configuration tag "F77" to libtool
checking for pkg-config... no
checking for GLIB... configure: error: The pkg-config script could not be found or is too old. Make sure it
is in your PATH or set the PKG_CONFIG environment variable to the full
path to pkg-config.
Alternatively, you may set the environment variables GLIB_CFLAGS
and GLIB_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
To get pkg-config, see <http://pkg-config.freedesktop.org/>.
See `config.log' for more details.
fes-a120d19nas:/backup/curlftpfs-0.9.2#
greetings
- mfe_TutorHi,
thanks for your help. Because ofpkg-config --cflags glib-2.0
-I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include
I had to remove the hole curlftpfs-0.9.2 dir. After new unpacking and executing ./configure & make it included the lib :)
Anyway there occoured some new problems. This links helped me:
http://developer.gnome.org/glib/2.30/gl ... iling.html
http://en.wikipedia.org/wiki/CFLAGS
http://www.linuxforums.org/forum/red-ha ... alloc.html
http://www.jkcs.de/blog/ftp-server-unter-linux-mounten
http://www.websyssupport.com/?page_id=222
So at the moment it passes make.
With make check there occours some errors like undefined reference libiconv_close.make check
Making check in compat
make[1]: Entering directory `/c/backup/curlftpfs-0.9.2/compat'
make[1]: Nothing to be done for `check'.
make[1]: Leaving directory `/c/backup/curlftpfs-0.9.2/compat'
Making check in doc
make[1]: Entering directory `/c/backup/curlftpfs-0.9.2/doc'
make[1]: Leaving directory `/c/backup/curlftpfs-0.9.2/doc'
make[1]: Entering directory `/c/backup/curlftpfs-0.9.2'
make[1]: Nothing to be done for `check-am'.
make[1]: Leaving directory `/c/backup/curlftpfs-0.9.2'
make[1]: Entering directory `/c/backup/curlftpfs-0.9.2/tests'
/bin/sh ../libtool --tag=CC --mode=link gcc -g -O2 -Wall -W -Wno-sign-compare -D_REENTRANT -I/usr/local/include/glib-2.0 -I/usr/local/lib/glib-2.0/include -D_FILE_OFFSET_BITS=64 -I/usr/local/include/fuse -I/usr/local/include -o ftpfs-ls_unittest ftpfs-ls_unittest.o ../libcurlftpfs.a -L/usr/local/lib -lglib-2.0 -pthread -L/usr/local/lib -lfuse -lrt -ldl -L/usr/local/lib -lcurl
gcc -g -O2 -Wall -W -Wno-sign-compare -D_REENTRANT -I/usr/local/include/glib-2.0 -I/usr/local/lib/glib-2.0/include -D_FILE_OFFSET_BITS=64 -I/usr/local/include/fuse -I/usr/local/include -o ftpfs-ls_unittest ftpfs-ls_unittest.o -pthread ../libcurlftpfs.a -L/usr/local/lib /usr/local/lib/libglib-2.0.so /usr/local/lib/libfuse.so -lrt -ldl /usr/local/lib/libcurl.so -Wl,--rpath -Wl,/usr/local/lib -Wl,--rpath -Wl,/usr/local/lib
../libcurlftpfs.a(charset_utils.o)(.text+0x38): In function `convert_charsets':
/backup/curlftpfs-0.9.2/charset_utils.c:26: undefined reference to `libiconv_open'
../libcurlftpfs.a(charset_utils.o)(.text+0xc0):/backup/curlftpfs-0.9.2/charset_utils.c:39: undefined reference to `libiconv'
../libcurlftpfs.a(charset_utils.o)(.text+0x15c):/backup/curlftpfs-0.9.2/charset_utils.c:50: undefined reference to `libiconv_close'
collect2: ld returned 1 exit status
make[1]: *** [ftpfs-ls_unittest] Error 1
make[1]: Leaving directory `/c/backup/curlftpfs-0.9.2/tests'
make: *** [test] Error 2
This is curious because i configured it with ./configure --build='sparc-linux' --without-libiconv
Because my IPS is since 2 days offline ( :evil: :x ) i cannt test a curlftpfs connection :(.curlftpfs --version
curlftpfs 0.9.2 libcurl/7.24.0 fuse/2.8curlftpfs --help
usage: curlftpfs <ftphost> <mountpoint>
CurlFtpFS options:
-o opt,[opt...] ftp options
-v --verbose make libcurl print verbose debug
-h --help print help
-V --version print version
FTP options:
ftpfs_debug print some debugging information
transform_symlinks prepend mountpoint to absolute symlink targets
disable_epsv use PASV, without trying EPSV first (default)
enable_epsv try EPSV before reverting to PASV
skip_pasv_ip skip the IP address for PASV
ftp_port=STR use PORT with address instead of PASV
disable_eprt use PORT, without trying EPRT first
ftp_method [multicwd/singlecwd] Control CWD usage
custom_list=STR Command used to list files. Defaults to "LIST -a"
tcp_nodelay use the TCP_NODELAY option
connect_timeout=N maximum time allowed for connection in seconds
ssl enable SSL/TLS for both control and data connections
ssl_control enable SSL/TLS only for control connection
ssl_try try SSL/TLS first but connect anyway
no_verify_hostname does not verify the hostname (SSL)
no_verify_peer does not verify the peer (SSL)
cert=STR client certificate file (SSL)
cert_type=STR certificate file type (DER/PEM/ENG) (SSL)
key=STR private key file name (SSL)
key_type=STR private key file type (DER/PEM/ENG) (SSL)
pass=STR pass phrase for the private key (SSL)
engine=STR crypto engine to use (SSL)
cacert=STR file with CA certificates to verify the peer (SSL)
capath=STR CA directory to verify peer against (SSL)
ciphers=STR SSL ciphers to use (SSL)
interface=STR specify network interface/address to use
krb4=STR enable krb4 with specified security level
proxy=STR use host:port HTTP proxy
proxytunnel operate through a HTTP proxy tunnel (using CONNECT)
proxy_anyauth pick "any" proxy authentication method
proxy_basic use Basic authentication on the proxy
proxy_digest use Digest authentication on the proxy
proxy_ntlm use NTLM authentication on the proxy
httpproxy use a HTTP proxy (default)
socks4 use a SOCKS4 proxy
socks5 use a SOCKS5 proxy
user=STR set server user and password
proxy_user=STR set proxy user and password
tlsv1 use TLSv1 (SSL)
sslv3 use SSLv3 (SSL)
ipv4 resolve name to IPv4 address
ipv6 resolve name to IPv6 address
utf8 try to transfer file list with utf-8 encoding
codepage=STR set the codepage the server uses
iocharset=STR set the charset used by the client
CurlFtpFS cache options:
cache=yes|no enable/disable cache (default: yes)
cache_timeout=SECS set timeout for stat, dir, link at once
default is 10 seconds
cache_stat_timeout=SECS set stat timeout
cache_dir_timeout=SECS set dir timeout
cache_link_timeout=SECS set link timeout
FUSE options:
-d -o debug enable debug output (implies -f)
-f foreground operation
-s disable multi-threaded operation
-o allow_other allow access to other users
-o allow_root allow access to root
-o nonempty allow mounts over non-empty file/dir
-o default_permissions enable permission checking by kernel
-o fsname=NAME set filesystem name
-o subtype=NAME set filesystem type
-o large_read issue large read requests (2.4 only)
-o max_read=N set maximum size of read requests
-o hard_remove immediate removal (don't hide files)
-o use_ino let filesystem set inode numbers
-o readdir_ino try to fill in d_ino in readdir
-o direct_io use direct I/O
-o kernel_cache cache files in kernel
-o [no]auto_cache enable caching based on modification times (off)
-o umask=M set file permissions (octal)
-o uid=N set file owner
-o gid=N set file group
-o entry_timeout=T cache timeout for names (1.0s)
-o negative_timeout=T cache timeout for deleted names (0.0s)
-o attr_timeout=T cache timeout for attributes (1.0s)
-o ac_attr_timeout=T auto cache timeout for attributes (attr_timeout)
-o intr allow requests to be interrupted
-o intr_signal=NUM signal to send on interrupt (30)
-o modules=M1[:M2...] names of modules to push onto filesystem stack
-o max_write=N set maximum size of write requests
-o max_readahead=N set maximum readahead
-o async_read perform reads asynchronously (default)
-o sync_read perform reads synchronously
-o atomic_o_trunc enable atomic open+truncate support
-o big_writes enable larger than 4kB writes
-o no_remote_lock disable remote file locking
Module options:
[subdir]
-o subdir=DIR prepend this directory to all paths (mandatory)
-o [no]rellinks transform absolute symlinks to relative
[iconv]
-o from_code=CHARSET original encoding of file names (default: UTF-8)
-o to_code=CHARSET new encoding of the file names (default: UTF-8)
I will report when my nas is back online :) - andbadAspirantcan you send me the binaries of curlftpfs for Duo?
By(t)e - mfe_TutorHello andbad,
I didn't recognize your post, sry :S
Because I reseted my NAS I lost the binaries. But I try to build them now. I will come back to you. greetings - mfe_TutorCompiled Software: curlftpfs
Download Debian packages (ReadyNAS Duov1):curl-7.29.0_7.29-1_sparc.deb
curlftpfs-0.9.2_0.9.2-1_sparc.deb
Instruction:
1.) The ReadyNAS Duov1 will be shipped out with an old installed libcurl debian package which needs to be updated. So first we have to remove this libarie.
2.) Make sure you got libcurl installed withdpkg -l | grep libcurl
3.) Remove it withapt-get remove libcurl3
4.) Check again if all libcurl libaries are removed withdpkg -l | grep libcurl
5.) Install some requried libaries like fuse withapt-get install sshfs
6.) Execute ( background information)mknod /dev/fuse -m 0666 c 10 229
7.)modprobe fuse
8.) Get the libcurl software withcd /c/media && wget http://www.get-the-solution.net/media/f ... _sparc.deb
9.) Get the software withcd /c/media && wget http://www.get-the-solution.net/media/f ... _sparc.deb
10.) Install the libcurl software withdpkg -i curl-7.29.0_7.29-1_sparc.deb
11.) Install the libcurlftpfs software withdpkg -i curlftpfs-0.9.2_0.9.2-1_sparc.deb
12.) Use it for examplecd /c/media && mkdir myftpsource
13.) Mount withcurlftpfs ftplogin:ftploginpassword@getthesolution.net myftpsource/
Have fun :)
No liability assumed
