Ronmoul
Feb 02, 2017Aspirant
Compatibility firmware 6.6.1 and Logitech Media Server NT 7.9.0.b7dfc80-nt1 for armel
Hi, i would like to know if the last version of the Logitech Media Server NT 7.9.0.b7dfc80-nt1 for armel is compatible with the firmware 6.6.1. for a ReadyNAS 104. Thanks a lot Ronald
- Feb 06, 2017
Hello Ronmoul,
Have you checked the available apps?
I tried on our own ARM based OS6 and found one from the available apps, that is 7.9.0-1477086729-nt1. I was able to install and it launched with username and password prompt.
JennC
Feb 03, 2017NETGEAR Employee Retired
Hello Ronmoul,
It still uses the same info about apps. So it should be working with it. Please check the post about the 6.6.1 from this link.
Ronmoul
Feb 05, 2017Aspirant
Hello JennC!
Thank's a lot for your response.
I had already read the information in the link you have provided. I was just confuse because in these pages there is a list of incompatible applications, like Logitech Media Server NT 7.9.0.b7dfc80-nt1 and at the same time there is a link to download the application (?)
Anyway, i have upgraded my Nas Rn104 with the firmware 6.6.1 and now the Logitech Media Server is not working at all ! too bad ...
Now I will wait for a fix for the Logitech Media Server
thank you
- JennCFeb 06, 2017NETGEAR Employee Retired
Hello Ronmoul,
- RonmoulFeb 06, 2017Aspirant
Hello!
Good news! Exactly as you said, i have removed the application and re-installed it from the list available on the web admin page: installation was ok and now the application is running fine!
Thank's a lot for your help
Ronald
Hello Ronmoul,
You are very much welcome!
Please feel free to post any suggestion, comments or question. We appreciate your contribution to the community!
