lachris
Nov 22, 2011Aspirant
Compiling on ReadyNas DUO
hi, I want to configure rrdtool 1.2.19 on my readynas duo. I installed all libs that are needed, so far as I read here in the forum. So I download that program, type #./configure --build=sparc...
lachris
Nov 24, 2011Aspirant
stefan,
there was an dir existing with these files in it....
i overwrote it with the ones from /usr/lib
then the configure started and ended with:
Findr 3rd-Party Libraries
checking for art_vpath_add_point in -lart_lgpl_2... no
checking for pkg-config... pkg-config
configure: WARNING:
* I found a copy of pkgconfig, but there is no libart-2.0.pc file around.
You may want to set the PKG_CONFIG_PATH variable to point to its
location.
configure: WARNING:
* I could not find a working copy of libart-2.0. Check config.log for hints on why
this is the case. Maybe you need to set LDFLAGS and CPPFLAGS appropriately
so that compiler and the linker can find libart_lgpl_2 and its header files. If
you have not installed libart-2.0, you can get it either from its original home on
ftp://ftp.gnome.org/pub/GNOME/sources/libart_lgpl/2.3/
You can find also find an archive copy on
http://oss.oetiker.ch/rrdtool/pub/libs
The last tested version of libart-2.0 is 2.3.17.
LIBS=-lm
LDFLAGS=
CPPFLAGS= -I/usr/include/libart-2.0
checking for zlibVersion in -lz... yes
checking zlib.h usability... yes
checking zlib.h presence... yes
checking for zlib.h... yes
checking for png_access_version_number in -lpng... no
checking for pkg-config... (cached) pkg-config
configure: WARNING:
* I found a copy of pkgconfig, but there is no libpng.pc file around.
location.
configure: WARNING:
* I could not find a working copy of libpng. Check config.log for hints on why
so that compiler and the linker can find libpng and its header files. If
you have not installed libpng, you can get it either from its original home on
http://prdownloads.sourceforge.net/libpng/
The last tested version of libpng is 1.2.10.
LIBS=-lz -lm
LDFLAGS=
CPPFLAGS=
checking for FT_Init_FreeType in -lfreetype... no
configure: WARNING:
* I found a copy of pkgconfig, but there is no freetype2.pc file around.
location.
configure: WARNING:
* I could not find a working copy of freetype2. Check config.log for hints on why
so that compiler and the linker can find libfreetype and its header files. If
you have not installed freetype2, you can get it either from its original home on
http://prdownloads.sourceforge.net/freetype/
The last tested version of freetype2 is 2.1.10.
LIBS=-lz -lm
LDFLAGS=
CPPFLAGS= -I/usr/include/freetype2
configure: error: Please fix the library issues listed above and try again.
Ok i found that libs on that page, please give me a short hint how, and where i have to install them that this script will find them
thanks a lot so far!
configure: WARNING:
location.
configure: WARNING:
LIBS=-lm
LDFLAGS=
configure: WARNING:
location.
configure: WARNING:
LIBS=-lz -lm
LDFLAGS=
CPPFLAGS=
configure: WARNING:
location.
configure: WARNING:
LIBS=-lz -lm
LDFLAGS=
