lachris
Nov 22, 2011Aspirant
Compiling on ReadyNas DUO
hi, I want to configure rrdtool 1.2.19 on my readynas duo. I installed all libs that are needed, so far as I read here in the forum. So I download that program, type #./configure --build=sparc...
WhoCares_
Nov 24, 2011Mentor
Instead of using the libs you found, I'd rather suggest you do an
If apt-get isn't working for you or if it's trying to update other stuff on the ReadyNAS, you can download the -dev packages from http://archive.debian.org
-Stefan
apt-get install <libname>-dev
-Stefan
