lachris
Nov 22, 2011Aspirant
Compiling on ReadyNas DUO
hi, I want to configure rrdtool 1.2.19 on my readynas duo. I installed all libs that are needed, so far as I read here in the forum. So I download that program, type #./configure --build=sparc...
WhoCares_
Nov 26, 2011Mentor
Just a bit but not much. The problems are essentially the same with the major difference that you can use apt-get more easily.
-Stefan
-Stefan
