maboehme
Sep 06, 2014Aspirant
Conflict between istat und LogitechMediaServer
Hi,
I'm running OS 6.1.9 (RC8) on a Pro6 and have Istat 1.01 installed as well es LMS 7.9 (nightly).
When I try to istall a new build of LMS I get the following message:
I had to unstall istat in order to be able to install LMS.
Is there someting I can do about it?
Best regards,
Martin
...:/tmp# dpkg -i logitechmediaserver_7.9.0~1409915004_all.deb
(Reading database ... 39060 files and directories currently installed.)
Preparing to replace logitechmediaserver 7.9.0~1409140270 (using logitechmediaserver_7.9.0~1409915004_all.deb) ...
Stopping Logitech Media Server.
Unpacking replacement logitechmediaserver ...
Setting up logitechmediaserver (7.9.0~1409915004) ...
insserv: script transmission: service transmission-daemon already provided!
insserv: warning: script 'istat' missing LSB tags and overrides
insserv: There is a loop between service logitechmediaserver and istat if stopped
insserv: loop involving service istat at depth 2
insserv: loop involving service logitechmediaserver at depth 1
insserv: Stopping istat depends on logitechmediaserver and therefore on system facility `$all' which can not be true!
insserv: exiting now without changing boot order!
update-rc.d: error: insserv rejected the script header
dpkg: error processing logitechmediaserver (--install):
subprocess installed post-installation script returned error exit status 1
Errors were encountered while processing:
logitechmediaserver
Best regards,
Martin
