theindustry
Dec 16, 2010Aspirant
Connecting to mySQL on the Duo?
Hi everyone, After reading on about how to connect to mySQL on the DUO, I tried the following, which throws the below shown output: #mysql -u admin -p ERROR 2002 (HY000): Can't connect to local ...
Quikdav
May 11, 2011Aspirant
Hi
I tried to launch mysql using the super poussin command line but I can't access the server using the Mysql Workbench
Then I have many daemons as below for mysqld when I display all the process that are running !!! why ?
admin 1306 1 8 00:20 ? 00:00:00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --pid-file=/var/run/mysqld/mysqld.pid --skip-locking --socket=/var/run/mysqld/mysqld.sock
admin 1307 1306 0 00:20 ? 00:00:00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --pid-file=/var/run/mysqld/mysqld.pid --skip-locking --socket=/var/run/mysqld/mysqld.sock
admin 1308 1307 0 00:20 ? 00:00:00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --pid-file=/var/run/mysqld/mysqld.pid --skip-locking --socket=/var/run/mysqld/mysqld.sock
admin 1309 1307 0 00:20 ? 00:00:00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --pid-file=/var/run/mysqld/mysqld.pid --skip-locking --socket=/var/run/mysqld/mysqld.sock
admin 1310 1307 0 00:20 ? 00:00:00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --pid-file=/var/run/mysqld/mysqld.pid --skip-locking --socket=/var/run/mysqld/mysqld.sock
admin 1311 1307 0 00:20 ? 00:00:00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --pid-file=/var/run/mysqld/mysqld.pid --skip-locking --socket=/var/run/mysqld/mysqld.sock
admin 1313 1307 0 00:20 ? 00:00:00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --pid-file=/var/run/mysqld/mysqld.pid --skip-locking --socket=/var/run/mysqld/mysqld.sock
admin 1314 1307 0 00:20 ? 00:00:00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --pid-file=/var/run/mysqld/mysqld.pid --skip-locking --socket=/var/run/mysqld/mysqld.sock
admin 1315 1307 0 00:20 ? 00:00:00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --pid-file=/var/run/mysqld/mysqld.pid --skip-locking --socket=/var/run/mysqld/mysqld.sock
admin 1316 1307 0 00:20 ? 00:00:00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --pid-file=/var/run/mysqld/mysqld.pid --skip-locking --socket=/var/run/mysqld/mysqld.sock
Thanks for your help
David
David
