theindustry
Dec 16, 2010Aspirant
Connecting to mySQL on the Duo?
Hi everyone, After reading on about how to connect to mySQL on the DUO, I tried the following, which throws the below shown output: #mysql -u admin -p ERROR 2002 (HY000): Can't connect to local ...
Quikdav
May 12, 2011Aspirant
Hi Stefan,
Sorry but I don't understand what you mean when you tell "it is using the localhost ip address 127.0.0.1 only" !!
I understand the mysql server is running on my DUO but you mean I can't access it from an other computer (with Mysql Workbench) even if specify the IP address (192.168.11.X) of my DUO in the connection string ?
So what I have to configure to connect to MySQL now the server is running ?
Thanks
David
Thanks
David
