theindustry
Dec 16, 2010Aspirant
Connecting to mySQL on the Duo?
Hi everyone, After reading on about how to connect to mySQL on the DUO, I tried the following, which throws the below shown output: #mysql -u admin -p ERROR 2002 (HY000): Can't connect to local ...
mfe_
Oct 19, 2011Tutor
Hi,
yesterday my MySQL worked. I installed the MySQL on Addon. Today I got when logging in:
Also starting the mysql daemon didnt changed my issue.
My my.cnf looks like that:
Trying to access the log will result in:
fes-a120d19nas:~# tail /var/log/mysql.log
tail: /var/log/mysql.log: No such file or directory
fes-a120d19nas:~#
Has anyone a Idea what is broken?
fes-a120d19nas:~# start-stop-daemon -S -q -b -x /usr/sbin/mysqld -- \
> --basedir=/usr --datadir=/var/lib/mysql --pid-file=/var/run/mysqld/mysqld.pid --skip-locking --socket=/var/run/mysqld/mysqld.sock
fes-a120d19nas:~# mysql -u root -p
Enter password:
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
fes-a120d19nas:~# ps -aux | grep mysql
Warning: bad syntax, perhaps a bogus '-'? See http://procps.sf.net/faq.html
root 7189 0.0 0.5 4256 1200 pts/0 S+ 17:20 0:00 grep mysql
[client]
port = 3306
socket = /var/run/mysqld/mysqld.sock
[mysqld_safe]
nice = 0
[mysqld]
[client]
port = 3306
[mysqld_safe]
nice = 0
[mysqld]
# * Basic Settings
user = admin
pid-file = /var/run/mysqld/mysqld.pid
port = 3306
basedir = /usr
datadir = /var/lib/mysql
tmpdir = /tmp
language = /usr/share/mysql/english
skip-external-locking
skip-name-resolve
# Instead of skip-networking the default is now to listen only on
# localhost which is more compatible and is not less secure.
bind-address = 0.0.0.0
#skip-networking
innodb_buffer_pool_size = 6M
key_buffer_size = 16k
myisam_sort_buffer_size = 16k
max_connection = 20
# * Fine Tuning
key_buffer = 16k
max_allowed_packet = 16M
thread_stack = 128K
# * Query Cache Configuration
query_cache_limit = 1048576
query_cache_size = 32768
query_cache_type = 1
# * Logging and Replication
# Both location gets rotated by the cronjob.
# Be aware that this log type is a performance killer.
log = /var/log/mysql.log
log = /var/log/mysql/mysql.log
# The following can be used as easy to replay backup logs or for replication.
server-id = 2
log-bin = /var/log/mysql/mysql-bin.log
# See /etc/mysql/debian-log-rotate.conf for the number of files kept.
max_binlog_size = 16384
server-id=2
skip-bdb
# * InnoDB
# InnoDB is enabled by default with a 10MB datafile in /var/lib/mysql/.
# Read the manual for more InnoDB related options. There are many!
[mysqldump]
quick
quote-names
[mysql]
#no-auto-rehash # faster start of mysql but no tab completition
[isamchk]
key_buffer = 16M
fes-a120d19nas:~#
