pdelges
Nov 04, 2013Guide
'Contacts & Calendars' add-on OS6 with MacOSX.6
Just tried to setup the Baïkal Apps under Mac OS.X.6
As the NAS OS6 UI doesn't work well with Safari under X.6.8 (I introduced a support ticket ages ago but nothing changed since) I used FireFox to config Baïkal, as I have to do for OS6. And it didn't work…
So I tried Safari to setup Baïkal on the NAS, and this worked!! :shock:
But setting up OSX.6's Address Book wasn't straighforward neither. This helped a lot: https://github.com/jeromeschneider/Baikal/issues/50
Now everything seems to run fine.
I didn't try CalDAV, only CardDAV.
p
p
- arnomcAspirantiCal sync also worked in carDAV for me on OS X ("Calendar" under mavericks). Have you tried to configure an iOS device for cardDAV with Baikal ?
Because I tried for my iPhone all possible adresses either w/o http:// ; with "principals" or "address books" ; and with or without SSL. None of this solution worked on iOS7.
arno - pdelgesGuideJust tried to set up CardDAV on an iPad under iOS6, but no adresses I tried worked so far…
p - arnomcAspirantThanks for trying :). I have read numerous posts on github and other places. I believe there is a incompatibility somewhere.
