WhoCares_
Apr 10, 2011Mentor
CouchPotato 0.40
CouchPotato 0.40
- Description:
CouchPotato (CP) is an automatic NZB and torrent downloader. You can keep a "movies I want"-list and it will search for NZBs/torrents of these movies every X hours. Once a movie is found, it will send it to SABnzbd or download the torrent to a specified directory. - Requirements: RAIDiator 4.1.6 or newer (may work with earlier versions but that's untested)
For this add-on to work,the Python2.6 add-on has to be installed on your ReadyNAS. - Platform: Sparc
- Current Version: CouchPotato 0.40 v0.1.4
- Features:
- Can be upgraded right on the ReadyNAS
- Automatic downloading and sending of NZBs to SABnzbd
- Automatic downloading of torrents files to a specified directory
- Easily add movies via IMDB UserScript
- Movie sorting & renaming
- Trailer downloading
- Quality options to download best available. Overwrite if better is found.
- A "Coming Soon" page with soon to be released DVD and Theater info.
- Support for NZBs.org, NZBMatrix, Newznab.com and ThePirateBay.
- Changes in this release:
- Fixes a problem where the SABnzbd integration could accidentally remove the API key for "TheMovieDB" from CouchPotato's config, thus making movie lookups from that souce impossible - Details/Installation:
- After installation of the add-on, CouchPotato's web interface can be accessed by typing http://<ip of your NAS>:5000/ in your browser's address field.As an alternative you can use the quick link from the add-on's section in the "Services" -> "Installed Add-ons" tab within Frontview. You will be presented with a login screen.
- The default username is admin with a default password of netgear1.
- After logging in with these credentials please configure HeadPhones to your needs - don't forget to change your password ;)
1 Reply
- WhoCares_MentorUpdated to: CouchPotato 0.40 v0.1.4
- Fixes a problem where the SABnzbd integration could accidentally remove the API key for "TheMovieDB" from CouchPotato's config, thus making movie lookups from that souce impossible.
