zibby72
Apr 07, 2016Aspirant
Dahua IPC-HDBW4421E(-AS)
So I'm trying to hook up this camera. http://www.dahuasecurity.com/products/ipc-hdbw4421e-as-998.html I can login to camera, etc, but Netgear surveillance is unable to find it. If I manually type a...
BrianL2
Apr 07, 2016NETGEAR Employee Retired
Hi zibby72,
This camera is not listed in our camera compatibility list. Possibly that's the reason why the system won't find it. Which ReadyNAS Surveillance desktop are you using on your PC? Also, which model and Firmware of ReadyNAS are you using?
Kind regards,
BrianL
NETGEAR Community Team
- zibby72Apr 08, 2016Aspirant
latest OS on ReadyNAS 316 using trial surveillance version. Camera works perfect with any other PC-NVR software, so I know there arent any issues on hardware side. As far as support, this camera isnt any different than other Dahua cameras that you support, so it should work. On the side note, I had Hikvision DS-2CD2732F-IS camera (is on your list) and your software couldnt find it too. This makes me wonder is i'm missing something with settings or your ReadyNAS surveillance just plain sucks.
- JennCApr 08, 2016NETGEAR Employee Retired
Hello zibby72,
You should be able to see the version of the ReadyNAS Surveillance when you go to Apps and see the app icon.
Also, it is still best you use the compatible one and not the one that is not listed when troubleshooting it.
- zibby72Apr 09, 2016AspirantFirmware Version: 1.4.2
As I said before, first camera I tried was on suported list and software couldnt detedt it.
