bte4
Feb 18, 2014Aspirant
ddclient setup on RN102
Trying to set up ddclient on RN102 and can't seem to figure it out. Currently running latest firmware 6.1.6. Downloaded and installed without a problem. However the "launch" button is grayed out. ...
arnomc
Mar 05, 2014Aspirant
for the greyed launch button it's pretty normal as it does the same thing for me. DDNS is a so light application that you don't need to turn it off, or you just uninstall it.
about your configfile. I can't see any problem. I nearly have the same file. I only noticed that you forgot to put a 'return chariot' before "# Mail failed updates..."
Maybe when you write your post. Just have a look in your file.
Have you reboot your NAS ? And you could also try to reset permissions access to the config file (maybe?).
note: recheck three times the login, pass, and address you couldn't wrote in this post.
