Darwin4Ever
Sep 14, 2024Tutor
RN102 OS6 Home folder
Hi,
I'm trying to find a solution for the following :
I need to give User-2 (read-only) access to the Home/User-1 folder.
I know how to proceed for other folders, but can't find a way to do that for Home-folders.
Thanks
RN102 OS 6.10.10
Darwin4Ever wrote:
Could you explain what and where you did for this : "and have disabled all network protocols for home, so these folders never show up"
Shared->Home Folders->Settings, then click on the access tab. From there turn off all the sharing protocols.
You can't (by design). Home folders are intended to be used exclusively by one user. The admin account can access them, but that is not read-only.
While home folders are useful for enterprises, I don't see much value for most home users. Personally I don't use them (and have disabled all network protocols for home, so these folders never show up).
I think you have a point there.
On regular (User-)folders read-only can be set.
Is there an easy and/or quick way to convert a home/user folder into a normal folder without losing any data ?
You can just a public share, and move the home contents to it.
If you use ssh, you can specify --relink on the CP command, and then delete the home folder contents afterwards. That would be faster if the home folder has a lot of data (and also would not increase the storage space during the move/copy). But if you aren't familiar with linux, I suggest just copying moving the contents from a PC.
Hi,
I don't see many settings for home but maybe I'm looking at the wrong place
Thank you
