Darwin4Ever
Sep 14, 2024Tutor
RN102 OS6 Home folder
Hi, I'm trying to find a solution for the following : I need to give User-2 (read-only) access to the Home/User-1 folder. I know how to proceed for other folders, but can't find a way to do ...
- Sep 14, 2024
Darwin4Ever wrote:
Could you explain what and where you did for this : "and have disabled all network protocols for home, so these folders never show up"
Shared->Home Folders->Settings, then click on the access tab. From there turn off all the sharing protocols.
Sep 14, 2024Guru - Experienced User
You can't (by design). Home folders are intended to be used exclusively by one user. The admin account can access them, but that is not read-only.
While home folders are useful for enterprises, I don't see much value for most home users. Personally I don't use them (and have disabled all network protocols for home, so these folders never show up).
Darwin4Ever
Sep 14, 2024Tutor
Hi,
I don't see many settings for home but maybe I'm looking at the wrong place
Thank you
- StephenBSep 14, 2024Guru - Experienced User
