bte4
Feb 18, 2014Aspirant
ddclient setup on RN102
Trying to set up ddclient on RN102 and can't seem to figure it out. Currently running latest firmware 6.1.6. Downloaded and installed without a problem. However the "launch" button is grayed out. ...
bte4
Mar 05, 2014Aspirant
Thanks for the reply. Triple checked the login, pass, and address, all of which are correct. Put the return in as you suggested. Also checked permissions, and they're rwx for everyone. I went back and specifically changed my ipaddress at dyndns.com to be incorrect to see if it will update correctly. Not sure how else to check it to see if it's working. Any ideas on how to check it to see if it is trying to do anything? Thanks so much!
