bte4
Feb 18, 2014Aspirant
ddclient setup on RN102
Trying to set up ddclient on RN102 and can't seem to figure it out. Currently running latest firmware 6.1.6. Downloaded and installed without a problem. However the "launch" button is grayed out. ...
sas137
May 20, 2015Aspirant
Anyone got that combination RN102 / ddclient /no-ip (or any other) really running?
Moved the system after the latest (6.2.4) update and wanted to use no-ip to get a dynamic dns entry .... no luck - ddclient exits with (according to loganalyzer) a missing perl-ssl-lib error:
followd by
the ON/OFF switch is after some time/page-reloads in the OFF-Position again.
What's going on?
Oh, and before anyone asks THAT - I did not tinker with the system ....
FATAL: Error loading the Perl module IO::Socket::SSL needed for SSL connect.
followd by
FATAL: On Debian, the package libio-socket-ssl-perl must be installed.
What's going on?
