bte4
Feb 18, 2014Aspirant
ddclient setup on RN102
Trying to set up ddclient on RN102 and can't seem to figure it out. Currently running latest firmware 6.1.6. Downloaded and installed without a problem. However the "launch" button is grayed out. ...
sas137
May 20, 2015Aspirant
eton wrote: Ok, straight to the point:
http://www.readynas.com/forum/viewtopic.php?p=436312#p436312
And register here:
https://www.changeip.com/accounts/register.php
Also straight to the point: Those
FATAL: Error loading the Perl module IO::Socket::SSL needed for SSL connect.
followd by
FATAL: On Debian, the package libio-socket-ssl-perl must be installed.
should be independent from where I registered, since the failure is even before connecting to an DynDNS service, right? Ans since I didn't uninstall anything from that system, I feel a bit, well, stumped ....
