bte4
Feb 18, 2014Aspirant
ddclient setup on RN102
Trying to set up ddclient on RN102 and can't seem to figure it out. Currently running latest firmware 6.1.6. Downloaded and installed without a problem. However the "launch" button is grayed out. ...
eton
May 20, 2015Luminary
sas137 wrote:
Also straight to the point: ThoseFATAL: Error loading the Perl module IO::Socket::SSL needed for SSL connect.
followd byFATAL: On Debian, the package libio-socket-ssl-perl must be installed.
should be independent from where I registered, since the failure is even before connecting to an DynDNS service, right? Ans since I didn't uninstall anything from that system, I feel a bit, well, stumped ....
Ah sorry. But that doesn't look like a ddclient error. More like problem with "Perl module IO" and "libio-socket-ssl-perl".
Have you tried to install the apt-get version of ddclient?
