bte4
Feb 18, 2014Aspirant
ddclient setup on RN102
Trying to set up ddclient on RN102 and can't seem to figure it out. Currently running latest firmware 6.1.6. Downloaded and installed without a problem. However the "launch" button is grayed out. ...
eton
May 21, 2015Luminary
sas137 wrote:
eton wrote:
Have you tried to install the apt-get version of ddclient?
Nope. I used the ddclient-version from the Apps-section of my RN102. It's labeled as Version 1.0.0 by Poussin. Installing anything else would require me to enable ssh-root access, thus voiding any warranty, right?
http://www.readynas.com/index.php?s=root+ssh
Please keep in mind that NETGEAR may deny support if you’ve enabled root access.
viewtopic.php?p=111042#p111042
By the way, installing the SSH add-on does not automatically void all of your tech support.
I actually think ssh-access is a must. Some things are just not possible to do via Frontview.
Poussin have not been that active here during last years. WhoCares is now the main add-on developer. RN102 uses an Arm CPU, right?
Not that many add-ons here: viewforum.php?f=158
WhoCares site: https://rnxtras.com/addons/category/readynas-os6-arm
But I can't find a ddclient add-on for OS 5 or 6 Arm.
If I where you I would enable ssh-access and install the apt-get add-on and then:
apt-get install ddclinet
