norbolt
Mar 27, 2013Aspirant
Debian Squeeze/Wheezy on Ultra 2?
Is there a way to get rid of all the netgear stuff and just install vanilla Debian on the Ultra 2? I connected a serial adapter and I'm able to fiddle with the BIOS and select a USB stick as the st...
chirpa
Mar 27, 2013Luminary
The BIOS on the 2/4bay always reverts to the internal flash. You could erase the /dev/md0 and unpack a newer Debian on it. You could then drop the kernel and initrd on the internal flash, a 128MB vfat.
To use your netinstall, hold the Backup button on boot will boot your external flash.
