norbolt
Mar 27, 2013Aspirant
Debian Squeeze/Wheezy on Ultra 2?
Is there a way to get rid of all the netgear stuff and just install vanilla Debian on the Ultra 2? I connected a serial adapter and I'm able to fiddle with the BIOS and select a USB stick as the st...
norbolt
Apr 03, 2013Aspirant
There's not much to share in that regard, as the port is readily available on the back of the unit. When viewed from the back, the ground pin is at your left, vcc at your right (most adapters don't need that connected). RX and TX are in the middle. I forget which is which, but you have a 50% chance to get it right and won't break anything by trying :)
Oh, and they communicate on 9600 baud by default.
