norbolt
Mar 27, 2013Aspirant
Debian Squeeze/Wheezy on Ultra 2?
Is there a way to get rid of all the netgear stuff and just install vanilla Debian on the Ultra 2? I connected a serial adapter and I'm able to fiddle with the BIOS and select a USB stick as the st...
mangrove
Jul 15, 2013Apprentice
mdgm wrote: If you wipe the Internal flash you would need to make use of USB Boot Recovery to restore it but the EEPROM data would be lost. Without the EEPROM data RAIDiator x86 4.2.x won't work.
Thanks. 6.x works though?
