norbolt
Mar 27, 2013Aspirant
Debian Squeeze/Wheezy on Ultra 2?
Is there a way to get rid of all the netgear stuff and just install vanilla Debian on the Ultra 2? I connected a serial adapter and I'm able to fiddle with the BIOS and select a USB stick as the st...
fflash
Jul 19, 2013Aspirant
Hello,
I have a problem to load the installer once reaching "boot:". When I enter "install video=off console=ttyS0,9600n8" I have the error "Undefined video mode number: 314". I tried to remove the video=off, but same error occured.
When happening, it proposes me to display available mode. I tried the first one "0" and then the following error happened:
I also tried: linux text console=ttyS0,9600,n8 but same error occured.
I have a ReadyNas ultra2, I prepared my debian installer USB key under MacOs by doing the following:
sudo gunzip -c boot.img.gz > /dev/disk2
Then I copied the iso file debian-7.1.0-i386-netinst.iso to the usb key.
Thanks for your help.
[ 1.045676] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
[ 1.049523] Pid: 1, comm: swapper Not tainted 3.9-1-486 #1 Debian 3.9.8-1
[ 1.049523] Call Trace:
[ 1.049523] [<c12b1573>] ? panic+0x6c/0x152
[ 1.049523] [<c1429d17>] ? mount_block_root+0x1e8/0x20a
[ 1.049523] [<c1002930>] ? do_alignment_check+0x15/0x73
[ 1.049523] [<c1429d77>] ? mount_root+0x3e/0x52
[ 1.049523] [<c1429e99>] ? prepare_namespace+0x10e/0x13e
[ 1.049523] [<c1429a88>] ? kernel_init_freeable+0x160/0x168
[ 1.049523] [<c12ae520>] ? kernel_init+0x5/0xb0
[ 1.049523] [<c12b8abb>] ? ret_from_kernel_thread+0x1b/0x30
[ 1.049523] [<c12ae51b>] ? rest_init+0x4f/0x4f
